Hi folks!
I have the Garmin Tri HRM but also have a MyZone HRM which is used by my gym for a range of activities and to accumulate points each month toward your status.
Previously I exclusively used my Garmin strap but over the last year or so I have been using the MyZone one. As a result, a bunch of the stats that I would usually get coming through to Garmin are no longer coming through, I guess because you only get them with the Garmin HRM.
Both straps auto-connect to my Fenix 5 as accessories so I was wondering if it is even possible to have both active at the same time, or would I need to disconnect the MyZone one from my Garmin watch if I wanted to get the data from the Garmin belt on the workouts while also having the MyZone belt active?
Unfortunately there's no Garmin/MyZone integration, so you have to wear that belt for the classes I do to have it register on the screens and to get the MEPS points each month for your workouts.
Thanks in advance!
