Hello, I would like to use the FR245 with the HRM-Pro chest strap. Can i record hrv data with this combination? If not, what combination is required or how do I record hrv data with the HRM-Pro standalone?
Thanks!
Z.
many newer Garmin watches have a setting called "log HRV" that has to be enabled under "physiological metrics"
Garmin destroyed the FirstBeat site just like they destroyed the forums here when they redid them, not giving a damn about lost knowledge but there used to be a hidden way for older Garmin watches to enable HRV logging by putting a tiny special FIT file into \GARMIN\NEWFILES on the watch
mirror: https://archive.is/xAWXW
the file used to be here but is now gone:
https://www.firstbeat.com/app/uploads/2015/10/enable_hrv_settings_file.zip
so you have to search google for enable_hrv_settings_file.zip
I have this file and it's this simple, only 38 bytes and just flips on one hidden setting for firstbeat features
***** enable_hrv_settings_file.fit ***** File size: 36 bytes, protocol ver: 1.00, profile ver: 1.50 File header CRC: 0xC104 file_id (0, type: 0, length: 2 bytes): type (0-1-ENUM): settings (2) hrm_profile (4, type: 0, length: 2 bytes): log_hrv (2-1-ENUM): 1 CRC: 0x7CC1 ***** enable_hrv_settings_file *****
Thanks! That‘s the solution.
Here is another article about it and although the fr245 is not mentioned there, it is the solution.
