I use HRM-PRO to analyze RR intervals in welltory, hvr-expert and others on a mobile phone (android) via bluetooth, everything works fine until a measurement is required for 5 minutes or more, because of the power saving settings, bluetooth turns off and the data stops do (for measurements, you need to be stationary).
The sensor does not have energy saving settings, can this problem be solved somehow? Can the next software versions provide for such a setting, or increase the time before turning off bluetooth at least up to 10 minutes? Or maybe on old firmwares differently and you can make a downgrade to fix this problem ??
I wonder if HRM-DUAL has the same time before turning off bluetooth?
