This is the second HRM-Tri that fails on me, it developed cracks in the plastic at the upper right screw. Why does it happens? Because of the metal cylinder forced into the plastic? (Because the cracks start from there) Or it is my improper use, if so, at what force these cracks develop? (I mean what are the values that generate these kind of cracks? because I can't remember stepping on it or pushing extreme force into it, for sure this product has some mechanical testing done in development, what are these values? Is this strap to be used with extra care compared to other straps?). I also have a Geonaute heartrate strap used in the same conditions without any issues (I bought it as a backup when the HRM-Tri failed), is this product mechanically stronger than the Garmin HRM strap? For example if I put this strap into my backpack with a 2-3kg laptop + some things that weight could make these cracks? Is this covered by the Garmin warranty or this voids the warranty? If it voids the warranty the why are there so many people have the exact same issue, all of them improper use this band? Where is the line drawn from a fragile product that should not be in production and improper customer use?
A DYI fix and comments from other users that report the same problem: https://youtu.be/62wb7rmt-LI
