Running Dynamic Pod position
I've seen various blogs etc suggest that the pod needs to be worn at the base of the spine. As a fat lass, I run with high waisted leggings - would it still work correct clipped to these?
  • It would still work, but most likely would give different readings than when positioned at waist height. But since the running dynamics have little value in general, I do not see a point in making any effort at placing the pod correctly.
