Hi all,
I have a fenix 6 pro and a wahoo tickrx HRM.
I currently have a nordictrack treadmill that uses ifit. ifit doesn't speak to connect, so file exports are required to move any run data. if I use the fenix and treadmill setting, the run distance is always off, as it calibrates for your given stride length, so unless you always run at the same speed, it will always differ.
question is, is there a treadmill that connects to the watch, or that can sync seamlessly to garmin connect, even if through another program?
thanks
Steve .
