Softstrap hrm
Hello all. I have 2 hrm that both give intermitant readings. Cutting out and going way to high. I borrowed another that works well to confirm. Is it worth trying to replace the strap? Or likely the pod is broken. Batteries changed. Cycling indoor and out. Thanks. Billy.
  • Look at the sensor's silver button connection, on the outside of male button section (aereola of sorts...lol) do you see any rust or burnt looking areas?  I have had two warrantied from that issue.  Gives similar erratic high/low readings.   If you see that... it's days are numbered or dead already.
    Recently my new HRM-Dual went through wash/dryer... worked for a while.  Then started having similar issues or communications probs, took out battery and it was wet/weird... so was circuit board. $5 Amazon warranty to the rescue :-) lol   Might be worth checking battery conditions (burst/leaky?)
    Also winter is tough on sensors due to static/dryness... still a problem when full sweaty?
