Good afternoon! Tacx alpine doesn't work with rouvy? When I connect my Tacx m3 to Rouvy, I can't connect Tacx alpine separately. It only flashes the connection to Tacx m3, but it doesn't connect to the Rouvy app at all. What should I do?
Garmin has been in contact with Rouvy regarding Tacx Alpine connectivity.
The grade simulation connectivity has to do with Rouvy's smart trainer connection protocol, for any users experiencing issues connecting…
The most recent update for NEO 3M added a sensor configuration option to the Tacx Training App: Using Secure Connection on Tacx Trainers
Our internal testing with NEO 3M and Rouvy allowed us to pair the…
Hello 9889473, thanks for your post.
Alpine pairs directly to your compatible Tacx smart trainer (NEO 3M) and will match the grade set by your training application (Rouvy, MyWhoosh). Any training platform that supports grade simulation on a smart trainer will also support grade simulation with Alpine.
If you have not, pair your Alpine with the Tacx Training App for important setup and pairing information following the setup video here: Tacx® Alpine | Getting Started | Garmin Support
Once your Alpine is paired to and setup with your Tacx NEO 3M, you should only need to pair the NEO 3M with Rouvy or other training apps - the Alpine's gradient simulation comes from the NEO 3M rather than the training application directly.
If the steps above do not allow you to pair, please reply with your consent for Garmin to reach out via your account email address so that we can collect more info.
DC Rainmaker mentions in his Alpine review some Rouvy users are experiencing issues with gradient simulation (Tacx Alpine Gradient Simulator In-Depth Review - DC Rainmaker). You may consider reaching out to Rouvy support for their suggestions.
Thanks for the added info, may I reach out to you via email to collect more details?
Your Alpine has 3 status LEDs, all flashing LEDs indicate the Alpine is searching for a connection or needs calibration. Check out: Alpine Manual - Status LEDs and Buttons
Can you provide any other details about troubleshooting you've tried in the Rouvy app? There are multiple options for connecting trainers and accessories, it would help to know what you are seeing
The grade simulation connectivity has to do with Rouvy's smart trainer connection protocol, for any users experiencing issues connecting Alpine with Rouvy, please reach out to Rouvy support to voice the concern and see what solutions are available.
9889473 I have reached out to you externally via email to learn more about your experience.
Our internal testing with NEO 3M and Rouvy allowed us to pair the NEO only while using the ANT+ connection type. Depending on what device is used to run Rouvy, ANT+ connections may be available.
The Alpine gradient simulator need only be paired with the compatible Tacx trainer, and does not pair to Rouvy directly: Pairing the Tacx Alpine with Your Trainer
Please reach out to Rouvy for further support regarding supported devices and connection types.
