Hi All. I noticed yesterday that Wahoo has partnered with Zwift to enable the zwift cog to be used with Wahoo trainers and therefore virtual shifting. PLEASE can Garmin/Tacx do something similar? Will this every happen? Best Wishes Jon
That is absolutly brilliant many thanks for the clarification. I will get over you Googlr play.
All the best
Mark
How do you pair the Zwift Click in QZ?
I am not being able to make it work. :-(
First of all, I think the Zwift Click firmware needs to be updated to 1.1.0. Then you would press a button on it to activate pairing mode since it shouldn't be paired with anything else at the same time. In QZ you go to Settings -> Accessories -> Zwift Devices and enable Zwift Click, and (from memory) maybe Refresh so the device shows up in the list. You also need to go to Tiles and enable the Gears tile so you can see it changing as you press the buttons on the Click. There's a video here, possibly for a slightly older version of QZ: https://www.youtube.com/watch?v=X3Q2WjbqMJo
If there's no Zwift Devices or Zwift Click, you might need to be running the beta version which the developer can give you access to.
Yes, did the whole process under guidance from the developer.
1.- Update Zwift Click firmware with Zwift companion app
2.- Install latest beta software (developer gave me access through the Facebook forum).
now it is working fine.
though I have to get it fully tested in a Zwift session … tomorrow.
