Hi
My Neo 2T disc keeps rolling after i finished the training.
I had to shut down the power in order to stop it.
Any one experienced the same, and if there is a solution for this.
Hi
It should turn off if the trainer controlling is switching off, sometimes it needs a 5-10sec after logout but probably the software didnt kill the connection somewhy , Do You control it via ANT+ or BT? Running on computer or mobile or tablet or ATV?
Maybe the IOS didnt kill the app from the memory, and in this case if your training ended on descent the trainer is stucking in it and spinning forever . Try to clear the app from IOS memory manually. Or before the end of the training, always check are You on ascent or not and if not, make an u-turn and finish the workout on uphill (in this case your trainer will stop 100% sure even if the app stayed in memory)
the same issue happend to me today on a Mac. But in my case even with the computer turned off. in fact i unpluged and pluged again the neo , did a couple of pedals strokes and rhe neo disc start Rolling and never stop by itself .. i just un unpluged again ...
what should i do ? .... thanks
From my experience the Neo 2T remembers the last gradient it was set to, even through a power off. If your last activity ended on a negative gradient, then the trainer will think it is always going down hill. As stated above, start an activity with a positive gradient.
