Tacx genius t2020
Hi,
I have so far been using Tacx 4 program, but have recently signed up for a monthly Tacx subscription and downloaded new Tacx app on Win 10. Smooth experience so far.
Then i plugged in my ANT+ dongle, but the desktop app refuses  to find my trainer. I am using Tacx Genius t2020.
Can someone advise how to connect the new app and the trainer? I’m getting really frustrated.
    0 Former Member over 5 years ago
    I have this problem as well.....Any solution?
    While the developers recently added ANT+ support to the Tacx Desktop App, they have not yet implemented support for the ANT+ FE-C protocol, so until such time as that is made available, Bluetooth is the only option for connecting a Tacx Smart Trainer to TDA. That said, unfortunately the older Tacx Genius T2020, which worked with TTS is neither Bluetooth or ANT+ FE-C compatible, so in order to use TDA, both of you will need a newer Tacx Smart trainer like the Genius Smart, Flux, Neo, Neo2, or Neo2T Smart .
    I have the same problem and still searching for an answer from support. My laptop crash down. Now the problem is, I can't install the TTS4, I can't use the tacx Desktop App and I can't use Zwift. So, anyone an idea how to use a Genius T2020 ? Is this trainer now trash...
    I have the same problem. The new software will not recognize the Tacx genius T2020
    cant connect to zwift using ant+ dongle
    cant connect to my wahoo elemnt using ant+
    cant connect to the new tacx application for my computer
    i wish there was a solution :(
    0 Former Member over 5 years ago in reply to Former Member
    Did you ever find a solution to this or are all T2020 i-Genius now redundant?
    AFAIK no. i sold it :(
    OK - Thank you.
    @Garmin..... Wow - so all of us who spent upwards of 600 on a premium product now have an expensive paperweight?
    0 Former Member over 4 years ago
    I have the same problem. I cant use it. Does Garmin respond? I dont get a proper answer
  • For Genius owners, the solution is simple: keep using the TTS4.
    Unofficial support page:
    http://w47.narod.ru/tts4.html
    http://w47.narod.ru/tts4.pdf
    New applications from Tacx (TDA, TTA) are a pale shadow compared to the TTS4.
