Bluetooth Keeps Disconnecting and Reconnecting to Phone
The Bluetooth connection of my Vivoactive 5 keeps disconnecting and reconnecting which caused missed notifications and sync issues. I've updated to 9.24, but issue still persists. Even I unpair and pair it again, it's still happening which is very frustrating. This is my first Garmin device and so far I'm not liking the experience. Anyone else facing the same issue?
Top Replies
All Replies
  • The issue is still not resolved for me. But observed that the watch looses the connection faster and longer when battery of the watch is at low charging level (<25%). This does not mean that the watch does not loose connection above this level. But when the connection is lost with charging level >25% the watch reconnects fast automatically. With charging level <25% the connection seems to get lost as soon as the display of the watch is switched off (quite sure about this). And reconnect only works when the displays of watch and phone are active (not so sure about this but it "feels" to be this way).
    Quite annoying...
    Is there anybody out there observing the same/alike behaviour?
  • I got my Vivoactive 5 a few weeks ago and its been great but its taken to dropping the phone overnight when I'm in bed (the phone and watch are less than a metre apart).  The connection comes back with powering the watch of and on but I've selected to update the software and I'll see if that solves it.
  • They need to fix the bug.
    Looking at all the Garmin and other forums where this is discussed and no real solution provided. The bug seems to happen:
    - Across a range of watches - so unlikely to be the watch device. If it is the watch they should fix that for all models.
    - Across a number of Android phones - so could be caused by an Android update.I have tried the fixes (BT Map version, exclude from power management, reverting to previous Android version, resetting everything to no avail).
    - With Garmin Connect on a range of Android OSs - so could be caused by Connect update.
    I think that it is Connect as my phone/tablet watch combination was working fine until a Connect update over a year ago.
    Two probable fixes:
    - Bose Soundtouch speakers had a similar problem a few years ago ie speaker inexplicably loses connection over wifi and then have to setup from scratch each time. It took them years to fix the wifi state and polling algorithm. So Connect on Android could be updated to maintain the last Bluetooth connection state and work out how to connect again when Connect is run rather than saying its lost and then having to setup again.The aim is to make the app more robust and overcome any OS issues that may be introduced.
    - If they can't fix the connection then update Android Connect so you don't need to step through the very clumsy setup process (I say no to just about every option). eg Was this watch previously connected - Y, then type 6 digit code.
  • I have allready given up connecting through Bluetooth. Ill sync with wifi instead. Mos of the times it will sync automatically.
    But not having the other "smartwatch" functions is a loss.
    Hope Garmin will still try to find a solution like you suggested.
  • I have the same issue of Bluetooth disconnecting after approx 2.50 mins and then have attempt to re pair and then connect does not recognise the watch.
  • I've been having this same issue (disconnect/reconnect many times per day, very annoying). I'm on a Pixel 9, went through all the troubleshooting steps like everyone else, the fix for me was as follows:
    Disconnect/un-pair watch from Garmin Connect, uninstall Garmin Connect, remove Garmin watch from Bluetooth devices in Android settings menu, update Android to newest version and restart phone, reinstall latest version of Garmin connect but do not log in. Open Bluetooth settings and pair new device, make sure watch is in pairing mode and pair. Then, log in to Garmin Connect account, finish syncing watch with Garmin Connect account.
    This is the only thing that worked for me, hope it helps someone.
  • This issue has started for me a few months ago, not entirely sure why. I tried resetting a number of times but nothing then one time trying that again, I couldn’t even pair my phone anymore. After several weeks, I finally managed to re-pair. Now it just connects and disconnects when it wants. Garmin didn’t want to hear anything about it. Feels incredibly disappointing that on a watch, fenix 6 which is worth a ton when bought new, they can just blow people off like this.
    Seriously considering this to be my last Garmin device after being with them for almost 15 years. I would also not recommend them anymore to anyone.
  • I see many people saying it's happening with android only but it's not. I just upgraded from Apple Watch to the Garmin vivoactive 5. Today is my 4th day, I have an Iphone 14 and the watch keeps disconnecting from my phone.
    If I'm home and leave my phone in my room to go to the kitchen right next to my room, it disconnects.
    I was at the park and my phone on my pocket and it was disconnecting all the time, like in 45 minutes it happened 17 times and I was missing notifications.
    I just contacted customer service and I'm waiting for the engineer to get back to me. If it keeps happening and there is no fixing I'll return and go back to Apple Watch because I never had any issues with them, my watch worked perfectly even if I was very far away from it, the only thing with them is the battery that doesn't last a day, but I'm ok with charging every day in order to have a watch that works perfectly.
  • How do you do that? I can't find the way to do it
  • Yep, another Android user here who keeps dropping connection when charging, then it doesn't reconnect. I have to do the merry dance over and over again. Sorry to say, but the vivo5 is trash. I love my other Garmin products, but this is shite
