Drain battery after run (and stop) activity
I noticed a problem that came with version 6.30. It WAS OK in version 6.10 and below, after switching to 6.20 and then to 6.30 I notice a problem with the battery. Important - I haven't uploaded any new widget or application for a long time. The watch works with exactly the same configuration. I have VA 4s
I start the activity (walk), it turns on in the GPS watch. I finish my activity after 30 minutes, but I have the impression that the GPS does not turn off - from that moment the battery starts to discharge as if the activity has never ended, i.e. the battery drops within a few or a dozen hours. I will do a scrap reset and the large, visible discharge of the battery will stop.
Nobody experienced a similar problem?
Someone wrote in this post about a similar problem but the solution did not come up
https://forums.garmin.com/sports-fitness/healthandwellness/f/vivoactive-4-series/255348/battery-drain-after-gps-activity
