This may sound like an odd question, but on my indoor bike, it's impossible to attach my speed sensor to the wheel or hub. I can only attach it to the pedal or arm. That works fine, but since the RPMs are much slower, to make the math work out, I will need to set the wheel size in the VA4 to something greater than 9999 mm, which is as high as it'll let me enter. I believe the correct value should be approximately 12,000 mm.
Is there a way around that max, or a way to change the wheel size from mm to inches? Maybe that would help.
