Just updated to SW 3.80 recently. Now I notice that my Vivoactive 4 is leaking battery like crazy, like 30% per day without doing any activity compare to 10-15% per day previously.
Anyone experiencing this issue with SW 3.80?
Yes, I have noticed an increase in battery drain rate with 3.80. The 3.80 "upgrade" happened Saturday around 5PM. I have not changed anything else. Watch face is Quattro. Pulse Ox is only on…
The same. I noted that my battery is draining a lot faster than normal. It went from 100% battery to 47% within 24 hours. I didn't do any activity. whereas before the update I was able to go 3-4 days with…
At mine it looks better too..
my experience is opposite of yours. before the BT update, my watch could last 4 days. After the update, it drained 30% in 12h.
Today, it is draining 4% per hour, no activities, Pulse Ox not running. Not good.
I found a solution : use GPS for a running or bicking activity.
Just after the 3.80 update : I lost about 3% battery per hour.
I started a 5 min bicking activity with GPS, and after I lost only 0.5% batery per hour.
I think it come from the feature "synchronise time with GPS" ... I think, after an update, the watch is trying to check the satelite time. If you don't start an activity to get a GPS signal, the watch keep trying to synchronise time.
Good luck
Where I can find this option on Vivoactive 4, probably there is no synchronise time with GPS option in this watch...
But not sure the "drain battery bug" come from this.
Maybe, just try to reboot your wtach, get a GPS signal with an activity, then check the battery drain.
Ok so according to the Vivoactive 4/4S Battery Life Information:
7-8 days (4S/4) smartwatch mode with activity tracking and 24/7 wrist-based heart rate monitoring |
So what exactly is smartwatch mode? I assume this does not include Pulse Ox (I do not have Pulse Ox on, as it readings were consistently low by about 10%). I would like to test this 7 day (I have a 4S) theory but am unsure of what they mean by Smartwatch Mode. Any ideas?
edited to add: Not sure if I am allowed to post a link to another thread but googling, I found this. https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-5-plus-series/168905/battery-life-what-is-smartwatch-mode-as-described-in-the-manual-for-12-days-battery-usage
I am going to try to reset my watch to default settings and see what battery life I get then. Has anyone else tried this?
