Just updated to SW 3.80 recently. Now I notice that my Vivoactive 4 is leaking battery like crazy, like 30% per day without doing any activity compare to 10-15% per day previously.
Anyone experiencing this issue with SW 3.80?
Yes, I have noticed an increase in battery drain rate with 3.80. The 3.80 "upgrade" happened Saturday around 5PM. I have not changed anything else. Watch face is Quattro. Pulse Ox is only on…
					The same. I noted that my battery is draining a lot faster than normal. It went from 100% battery to 47% within 24 hours. I didn't do any activity. whereas before the update I was able to go 3-4 days with…
					Had this all the time since I bought it. 36h from 100% to 10 %, after update only 24h left. This morning I notived that watch wasn´t connected to Phone any more and.... only 2% less over whole night. Seems there is an issue with power management.
					I tested everything - it is bluetooth - after using bluetooth for some time it sometimes randomly goes from ~0,3 - 0,5% an hour to 2 % an hour. To stop the drain it is not enough to turn off bluetooth, I have to restart the watch.
Even with custom watchface with seconds, high brightness, alarms, lots of playing around I have nice battery life... With pulse ox it is less but still impressive!
Possible reasons for sporadic BT (phone connection) battery drain:
Maybe an issue with walking out of BT range of my phone? If just turn on bluetooth for syncing and after that I turn BT off again (without restarting watch) and I am fine!
Maybe BT battery consumption goes up rapidly after my phone looses the internet connection?
 Problem with my phone?
BT Firmware has to be improved I guess!
Yes, I have noticed an increase in battery drain rate with 3.80. The 3.80 "upgrade" happened Saturday around 5PM. I have not changed anything else. Watch face is Quattro. Pulse Ox is only on at night. I took it off the charger at 100% 13 hours ago, and it is already down to 80%.
					The same. I noted that my battery is draining a lot faster than normal. It went from 100% battery to 47% within 24 hours. I didn't do any activity. whereas before the update I was able to go 3-4 days with 2-5km (20-50min) daily runs and 10-15min workouts.
User 7404875, suggested that you have to switch off the VA4 and then back on. I did it and so far it seemed to work. Battery life now seems better than before. the battery dropped 18% within 24 hours.
Thanks 7404875.
					today i have an issue with my battery va4
i bought it 3 days ago on saturday and today was the first time that i charged it. i charged it 600 to 800 pm to get 100%
after that it drained 16% in 3 hours
whats going on to my watch? what should i do?
