Same issues as others I believe. Not finished paying for my watch yet so might return if can’t be fixed
Not sure if you’re a golfer but this has proved really inconvenient! I’ve had a better experience with other makes of gps. But I like the watch so will be patient (for a while). I was in contact…
I want to add my experience. I noticed that I can get the yardages to update once I move past the tee box into the fairway by cycling to the next hole, then back. The issue with this workaround is that…
I too am having this same issue and it’s definitely a bummer.
Hello, I believe you might be experiencing the same thing here: https://forums.garmin.com/sports-fitness/healthandwellness/f/venu-3-series/391867/golf-yardages-not-updating---venu-3 If so, we are working on a fix!
In the mean time, transition the watch to the next hole through the golf round menu on the Venu and then switch it back to the hole and the distances should re-appear on the watch.
Not sure if you’re a golfer but this has proved really inconvenient! I’ve had a better experience with other makes of gps. But I like the watch so will be patient (for a while). I was in contact with someone from Garmin today who said there have been no other cases like mine
I want to add my experience. I noticed that I can get the yardages to update once I move past the tee box into the fairway by cycling to the next hole, then back. The issue with this workaround is that reviewing the shots on your phone later is a total mess. One shot does not lead to the next.
I've only had the watch for a month, and golf was a huge reason for the purchase. Fingers crossed for the fix.
