I saw the previous posts but my watch has the current version. Are others experiencing the same issue with rapid batter drain after 40% with a VENU 2 V19.05.
I have the exact same problem. It also sometimes turns off during activity.
yes same behaviour, also turning off during activitiy :-(
I have the same issue, my watch has a battery life of about 24 hours since the last update from a few days ago. I've also noticed that the graphs showing stress are full of gaps, much larger than before.
Hi :-) I had a similar behaviour. Battery was dying when the device was around 20% (also often during activities) and total battery life was about 24 hours. In my case it was just the battery itself. I've changed the battery and now everything works again. perfectly
Hello
Did you change the battery yourself?
I found some video on youtube, that looks quit difficult.
yes. if you do it the first time it is a bit challenging, since the devices are not made to change the battery. if you know what to do it takes you 10 minutes. the first time maybe 2h.
