Greetings:
I can’t seem to find a way or the option to turn on Hydration notification either on the Venu 2 watch running SW 5.33 or on the Garmin Connect app. Any idea?
Thanks,
Hello 9709615. Please see the FAQ linked below for more on this:
Using the Hydration Widget on Your Garmin Watch
all the HYDRATION features (proper tracking, reliable alerts, etc.) have been working inititally, which was an indication that it could be a firmware/software related issue.
but as the support still have…
FYI [Redacted]
Replacement finally arrived and everything seems to be working normally again!
See updates in the other threads:
https://forums.garmin.com/sports-fitness/healthandwellness/f/venu-2/274923…
Please let us know, if the alerts work on your watch.
Other users including myself are experiencing problems (See here: forums.garmin.com/.../hydration-app-hydration-alerts-not-working )
Thank you for your help.
There is no such menu as highlighted on my watch. However, the hydration notification suddenly works out of the blue without needing to do anything.
I notice in general, since I got this Venu 2 several days ago, nothing works the first time. I have to contact support multiple times and keep trying on my own to download, remove and re-install watch faces and widgets several time. Eventually they will works after x attempts. Most disappointingly is the battery life and always on display only shows HH:MM and date. Long story short, with minimal daily usage, no notification, gps, exercising, sleeping tracking, vo2 max reading etc activities, it last about 4 - 5 days max.
Overall, not a good experience for a $400 watch imo.
but as the support still have not found a solution, i actually did return the watch. currently waiting for the replacement, it takes GARMIN about 2 weeks here, but it is finally on the way back... will certainly update after testing with the new watch.
FYI [Redacted]
https://forums.garmin.com/sports-fitness/healthandwellness/f/venu-2/274923/hydration-app-hydration-alerts-not-working/1341709#1341709
https://forums.garmin.com/sports-fitness/healthandwellness/f/venu-2/274568/hydration-not-resetting-each-day?pifragment-443=5#pifragment-443=4
Hey BikerWithAVenu2! I am glad you have found a resolution to your issues. Thank you for keeping us all updated with the progress and resolution.
Thanks Garmin-Kevin
I would not call "returning the watch" a solution, but I am also happy, that this is not bugging me any more. Hopefully, it stays that way....
