Hi,
I discovered a problem with the connection port of the Venu 2 where the loading/sync cable is plugged in. The Venu 2 was charged, but my PC did not recognised the watch. After several tests with plug/unplug, different cables and usb-ports I started to bend the cable a little bit at the point it is plugged into the watch and suddenly my pc recognised it.
Seems to me like the same problem I had with my first Fenix 5x where connection was very unstable due to the pins at the port. Afterwards the next batch was built with gold plated connectors and the problem dissappeared.
Has anyone else the same problem?
Best Regards
