New Firmware, Old Problem
My watch was working normally for a month and a half then without warning or changes to settings it started draining at about 4% an hour.
I added the beta firmware (9.14) and did a full factory reset and it was ok again—for two weeks. Starting 10 May it was again draining faster than normal (though slower than before, at about 2% hr). ***BTW, both drain amounts (the 4% and 2%) were notwithstanding if I was using GPS or Ox or not. It's just a standard 4 or 2%.
Last night, I was about to do another reset when I noticed that there was a new firmware ready (9.17) so I installed that and did a power cycle. Over night I tested to see if that solved the problem. It did not.
So this morning I did a full factory reset as that worked last time. But no. Still 2% drain per hour.
