Battery drain when not in use
Do you also experience battery drain of 10% or more during the day when the device is not in use?
I've noticed that when I'm not using the Index Sleep, i.e. during the day, it regularly consumes 10% or more of its battery, even though I place it so that the sensor is not covered and I don't move it throughout the day.
With the pulse oximeter activated, I only get 5 days or less before I have to recharge it. The instructions say “up to 7 nights with SpO2,” so that's not quite right.
  •  I am doing the same thing.  Tracking batter usage when I take the ISM off in the morning and putting it on again at night.  I am seeing similar results to you.  The ISM consumes anywhere from 12% to 15% usage at night.
    I find that between when I take the ISM off to when I put the ISM on, the battery drain can be anywhere from 3% to 6%.
    Like you, the ISM sits sensor up, inside out, not being moved when not in use.
    I will publish my results similar to what you did when I have some time and have collected more information.  I am getting on average five nights of use before recharging.  And like you, when I put the ISM on after a charge it reports 99% full in GC.
  • My experience seems similar to this.
    I'm pretty sure that when I first got it,the drain between Morning and evening was only 1-2%. It seems after one of the earlier updates the excessive battery drain was introduced.
    For reference, I take it off and turn the band inside out and place the sensor side facing up.
    I've also had a couple of instances where the unit seems to have performed a factory reset with the only solution being to unpair and re-adding it in Garmin connect.
  •  Agreed.  When I first had the ISM I was getting seven or more nights of use.  Subsequently that has dropped to about five.
    No factory resets for me though.  The ISM has been working as it should.
    I am continuing to track the battery usage in night and morning.  I'll post my results once I have a weeks worth of data.
  • Ok, I have tracked my battery usage for the past week.  Here is what I have:
    Day Start End Difference from previous day
    Friday 99% 85% -
    Saturday 84% 72% 1%
    Sunday 70% 57% 2%
    Monday 54% 41% 3%
    Tuesday 40% 23% 1%
    Wednesday 22% 8% -
    So.  If you add up the percentage decrease between when I take the ISM off in the AM to when I put the ISM on in the PM, total battery loss is 7%.
    Add the 7% to the remaining 8% and we get 15%.  The missing extra day of use for a full week of use.
