Disapointed: No metrics shown or synced.
I thought that buying Garmin would mean quality, easy setup and use. Boy, was I wrong.
So for starters the scale connects to my home WIFI  but from there doesn't work at all. It shows my weight but then just gives me the "User icon" with a ? in it and then shows me a cogwheel before shutting down. I managed to solve this however making it connect to my mobile hot spot. This is irritating as *** but I can live with it.
It took me about an over to get it to update because the manual is quite sparse on information to say the least. In rage I turned of the Bluetooth on my phone and voila, it updated.
Now I wanted to take my measurements. Problem is that the only measurement it shows or send/syncs to my Garmin connect app is weight... If I just wanted weight I could have used my analog scale I already have. Does anybode else have this same issue I have an android version of the app if that helps.
I have tried to configure the scale 10 times adding these metrics syncing it to the scale. I have tried to remove the scale and reconnect it. I also tried to factory reset it and nothing works. Still only shows me the weight and the weather...THE WEATHER... That has to be the least useuufl
So I get the "feet symbol" while standing on the scale so I guess it is measuring correctly but nothing gets shown or synced.
Has anybody else encountered these issue and managed to solve them?
