Varia RTL515 battery life with Edge 1040
Hello,
I have my Varia RTL515 for almost 3 years. Not long ago, i bought Edge1040 and i have a problem with battery life of my Varia... that problem was maybe present the whole time i had it(used with Edge820), but just this year i started to do a little longer rides so i noticed the short battery life.
According to manual:
RTL515 battery life
Up to 6 hr. in solid mode
Up to 8 hr. in peloton mode
Up to 6 hr. in night flash mode
Up to 16 hr. in day flash mode
Up to 3 mo. in standby mode
Since i have my Varia connected to Edge, there are not the same light modes in the lights settings as it is in the Varia manual. I have my lights set to "automatic" and i get warning about low battery after 3 and half hours.... Which is much less, than it should be in the brightest mode according to the manual. Is this normal?
What can i do with setting to get at least 6 hours?
Thanks in advance for any suggestions.
  • I do not know what "automatic" mode does because I've never used it.
    I would recommend using SmartBikeLights app for controlling your Varia https://github.com/maca88/SmartBikeLights
    I use since a very long time (820, 1030, 1040)
    For example you can configure it to only day flash when a vehicle approach is detected and, afterwards, to turn off automatically..
    You can also use the speed, time of day, sunset/sunrise to configure its modes.
    I do not know if it can help you with the battery life. but it is very nice to use.
  • For example you can configure it to only day flash when a vehicle approach is detected and, afterwards, to turn off automatically..
    This is exactly what am i looking for :) Since i ride only during daylight, this is what i need... i'll try that and we will see what will the battery life be in this scenario. To be honest i thought this is the situation right now with the "Automatic" mode in Edge... but who knows, when Garmin can't even keep their settings same in 2 devices for the same sensor... Thanks
    And here is something to the "Automatic" mode i've found here on forums...
    https://forums.garmin.com/sports-fitness/cycling/f/varia-series/364319/light-modes-on-varia-vs-light-modes-in-edge-lights-network
    They are not able to be consistent with their own devices.... so when you connect Varia to Edge, manual for Varia is useless suddenly.
  • Well ... problem solved. Today i did a 4hr 30min ride and with day flash... continuous, not only when a car is approaching... i still had like 60% of Varia battery available....  Thank you for showing me that SmartBikeLights app Slight smile
    To summarize: Garmin sucks when they basicaly bloodsuck energy from their devices if you use them with their settings....OMG.
  • I have an 840 with a Varia rear light and in automatic mode it defaults to day flash during the day. That's what Automatic is supposed to do and it's the default setting.
    If Automatic is doing something else, I would check that you haven't overridden the default by putting it in 'individual' mode in the device settings.
    Another way of changing the light setting is using the button on the top.  It's also easy to do this by accident and again it will put in individual mode on the Edge. Granted this is confusing!
  • Hi, i had it in automatic mode on my 1040 - same mode as you described. And it worked just like yours  - day flash during the day. But for some unknown reason it was draining battery like bloodsucker with that mode selected.
    My problem was solved after i started using the SmartBikeLights app which now controls the lights - And in the same day flash mode i get at least double the battery life Slight smile
  • I'm glad you've managed to improve it but not sure if you've solved the problem.  I get almost 14 hours in day flash mode (it survived a 212 mile ride I did last summer). So if you're now getting 6 instead of 3 hours before a battery warning, there's still something wrong.
  • Hi, i was asking to at least 6hrs originally... but after i started to use the app (recommeded above) to control the lights i have at least 10hours of battery life. Longest ride i ever did was 6,5 hours... And in my plans for this year are rides with maximum between 8-10 hours. So now i am 100% satisfied. My Varia is now almost 4 years old, so it may be also affected by this :)
    Worst on this situation is the original cause of the problem... which is Garmin itself. When you connect Varia to Edge... suddenly you do not have lightmodes described in the Varia manual available. But there are new names in Edge for the light modes which act god knows how and drains the battery very differently compared to Varia being used without Edge.
    And thanks to the app i was recommended to use (link above) I now have again the original lightmodes at my disposal = with effectof the original battery life.
    1. ince you mentioned using "automatic," try switching to a specific mode like "peloton" or "day flash" to see if that helps. Sometimes, the automatic setting may not optimize for battery life.
  • That is unfortunately the main problem i have described. I am using Varia with my Edge1040... And as soon as you connect Varia to Edge, menu with available flash modes of your Varia is different from the Varia manual, and you can not select peloton or day flash because those options are not available there :) Only way for me to get the original options back was using the IQ store miniapp i have now in my Edge and that is controlling Varia.
  • Are you looking in the right place?  Note that - confusingly - there are Light Network Settings and Light Mode Settings.
    For the former, you can go into the menu then sensors\lights\network options\light mode you should find the same modes as listed in the RTL 515 manual. Varia Rearview Radar RTL515/RTL516 - Light Network Settings .
    You get Auto, Individual, Trail and High Visibility.  I leave mine in Auto as it uses the sunrise sunset time to put the varia in day flash and night flash modes automatically.
    To get the Light Mode Settings, you can also  use the swipe down menu on the Edge and then swipe left, assuming you've left the pages as at default.  On the page for the Varia, you'll see an 'override light mode'.  These are also listed in the manual, on the next page, as solid, flash, off and peloton.  They match the modes that you get by cycling the physical button on the device.
    Note if you use the physical button, it will show Individual in the Edge but won't display what override mode you are in.  To restore control from the Edge, change the mode back to Auto.
