Upgrade from Edge 1000 to Edge 1030 Plus everything ok except for the UT-800.
I've setup the 1030 Plus from scratch, not importing sensors.
The Varia UT-800 is not even shown when searching for sensor (either All or only lights)
You can add it manually via the ANT id, and it will connect, but as soon as the RTL-500 is connected all the lights are disconnected.
I've try to remove the radar and search for the headlight, no luck.
UT-800 Firmware: 2.40
Edge 1030 Plus Firmware: 2.30
