Garmin Varia Radar Rear Light control via Edge 1000
I've just bought a Garmin Varia Radar Rear Light and paired it with my Edge 1000. It shows up as a Radar device. The Radar Rear Light is running software version 3.60. My Edge 1000 is running software version 14.20.
Is there a way to control the light on/off whilst keeping the radar functionality? I don't have any 'Light Network' menu options on the Edge 1000 and it looks like the light is paired as a radar device and not a light device.
The only options I have when I go to Sensors --> <Radar Device Number> --> Sensor Details --> Alert Settings are:
Color Overlay: On/Off
Tones: On/Off
Vehicle Column: Right/Left
I cannot find any way to control the light output itself. During the daytime I would like to switch off the light output from the Varia Radar Rear Light whilst keeping the radar functionality active.
  • It's under Lights. There, you should find your radar listed. But for the radar light mode options to appear, you must have your Light Network options set to "Individual".
    Unfortunately I cannot see a 'Lights'' option on my Garmin Edge 1000 and neither do I see a 'Light Network' menu option. The RTL 500 is paired as a Radar device in my Edge 1000 and not a light.
    I think I may have finally got this working! I had to add a new sensor and it found 'Light'. So I effectively have two sensors added for the RTL 500 - a Radar sensor and a Lights sensor. From the Lights sensor I can set it up as I want.
