Has anyone else had a problem with connecting sensors since upgrading to version 12.30 I can no longer connect my Edge remote or Cadence sensors
Hello everyone,
We have released Official software version 12.4 for the Edge Explore 820. It will revert back to previous software while we investigate reports of sensor dropouts. It can be found at the…
We are actively working on a resolution. I apologize for any inconvenience this has caused and I will update the forum post when we have a resolution.
Hi Garmin Matthew, can you tell us, when we can expect an new error-free update for our Garmin 820? 1 day, 1 week, 1month? It would help us in our decisions.
I have the same problem, the radar the cadence and heart rate sensors works for about 20 mins and they stops
Hello,
I apologize to all users that are experiencing and we it is a very bad experience to have sensor dropouts or connection issues. We are wanting to research this problem and we would like some examples of this happening in your activity. Could you post the activity file here or a link to your activity from Garmin Connect?
If you are experiencing a problem during pairing, could you provide a video of this occurring?
Thank you for any information provided.
I'm having same problems in Edge 820 after upgrading to 12.30. Heart rate sensor is connecting and unconnecting all the time. It shows heart rate only few seconds in a minute or two and then disappears. Haven't tested yet what is happening with other sensors.
Same problem here with hrm and cadence sensor dropping out since updating to 12:30. I tried deleting the sensor, restarting and then connecting but that didn't work, still dropping out.
I have got the same problem with my heart rat and my Vector 3 power sensor since updating to 12.30. New coupling couldn't help. With my heart rate sensor there was no connection established for a 2 hour ride
I have gone back to firmware version 12.10 and all is working well again
So there is a problem with version 12.30
How do you go back a version?
Link to activity from Garmin connect https://connect.garmin.com/modern/activity/4751599141
I did manually input the distance and calories for my own records
see https://forums.garmin.com/sports-fitness/cycling/f/edge-520-520-plus/208199/firmware-downgrade
it works for edge 820 also
You will need to re-connect all your ant+ sensors
