Transfer files, courses from edge
Hello,
 Have found the Explore 1000, and other older Edge like 820 have an option to transfer or share courses from one Edge to other. I don´t find this option on Explore 2.
 I find easy to create a course on the Explore, I should like to transfer it to my Fenix 6 pro, but I don´t find any way to do it , even with connect IQ,  unless use a computer.
 What I want to do is send a course or saved locations  from my Explore 2 to my Fenix 6.
  Seems that all apps on Coonect IQ work only from smpartphone to device direction, but seems no way to do in the other direction, from the Device to Connect.
 Any ideas?
Thank you.
Top Replies
  • over 1 year ago in reply to 8566077 +1 verified
    How many people do this? It seems like most people would just use the Explore (with its larger…
  • Have just tried explore.garmin web.., I remembered it can used saved waypoints and... surprise.. Edge are not compatilbe, why?  Because low edge user used it? They can´t?
    Part of the reason…
All Replies
  • Yes, there was a way of transferring courses (not locations) from one Edge to another. It was a bit rough.
    The 1040 (and later Edges) dropped that feature. So, I wouldn't expect it on any other new device.
    Outside of the (basically obsolete) device-to-device transfer, there is no way of uploading a course from the Edge. Except by plugging it into a computer.
    The support of locations is also a bit rough. It doesn't seem Garmin expects people to want to transfer them to other devices.
    I think Garmin BaseCamp will read the locations from a plugged-in device. Copying the locations.fit file is a possibility but it would overwrite any locations on the device it was copied to.
    It's unlikely that Garmin is going to change anything about this.
  • Thank you for confirm. For me seems that Garmin like all data be on the cloud, activities, health stats, trails and so on.
  • The web/cloud stuff means Garmin only has to write code once.
    I'm guessing Garmin dropped the device-to-device transfers because not many people used it. it was kind of rough, and they wanted room for more valuable features.
    Keep in mind that you still can muck with the files.
    I wrote a "workbench" Windows program that makes mucking with files more convenient. (It does cost $5 but it has a generous 1 month trial.)
    One thing it can do is read the locations file and split-out the locations separately. You could then copy these to another device (without overwriting the existing locations).
    sites.google.com/.../grouteloader
  • On Fenix 6 Pro, "create course" feature doesn´t work for me, just makes a straight line. On Explore and Explore 2 works fine and even is more practical in some way. If you have different saved locations, you can add them to the course and preview easily the altitude . Can change the location orders, so change easy have a preview of the course altitude and now, with climbpro a preview of the climbs. You haven´t it on Garmin connect. I mean what you say regarding writing one code, but should be a goal just to can upload a course created on the Explore to connect. You can send from connect to device but from device to connect can all upload activities.  I should be useful to can send courses from Explore to connect since already have that feature working ok on Explore, so could just upload to connect and then sent to Fenix. Of course you can do it the course on connect, but as I said, on Eplore you can preview climpro data, and use already saved locations and combine them easier.
    Regarding your windows app, sounds ok,  but is supposed you may be anywhere on the road and not have the computer there.
  • I find easy to create a course on the Explore, I should like to transfer it to my Fenix 6 pro,
    How many people do this? It seems like most people would just use the Explore (with its larger screen).
    I expect the intersection of Edge owners and Fenix owners (people who own both) is fairly small.
    That is a bug. right? An existing feature should be made to work before adding new features.
    The course files don't contain the editing information. All that gets saved are the track points tracing the path and the "course points".
    You can import courses into the Garmin Connect website but you have to upload the file. You only get the track points (not the course points).
    There are important differences between the two.
    I suspect very few people want to copy a course from the device to Connect (and those people can import the course file). Anyway. it's not generally not that hard to recreate a course.
    Activities are precious "one of a kind" files that are impossible to recreate. And many more people are interested in activity files (and the related statistics) than use navigation on the devices overall. (Of course, It's likely that a much larger percentage of Explore users use navigation over the other units.) The number of people interested in uploading courses created on the device is likely much smaller still.
    I wonder what sorts of locations you are using for this. The online course creators show the elevation. So, it wouldn't be that hard to show the climbpro climbs (but it might be hard to show them exactly like the Edges do).
    I don't really do course creation on my 1030+ (the screen is too small).
    I don't think many people would be doing this. If so, it's not going to be a feature that would help them sell units. Keep in mind that these are very limited devices. They aren't able to do every "little" thing that people want.
    It seems very hard to get Garmin to add new features. It's more productive to learn to work with the limitations of the devices than wait for them to be improved.
    Oh well. You didn't mention that need (though, it's not too surprising). Anyway, some people carry laptops! There are even small Windows tablets (I own one).
    One might be able to use cables to connect the devices to an Android phone/tablet. I've done it.
  • I suspect the Fenix is a bug.
     The conclusion about "there must be no many people doing that" because if so should be implemented is a fish that bits it´s tail.
    How can most people "use" on a way that can´t be done? you are right that I can see the altitude on Garmin connect, save the  course there and send to devices. You can´t create a course on the device and send to connect, so is imposible to know "how much people want to use it".., in fact I have searched and have found different threads asking about this, and reply was "you can´t",  may other features have bee added from forum suggestions, (unless Garmin diviner, they never could add a feature "used for many people", since is not added yet right?
    I can make the course on mobile connect, yes, and the altitude info you are right, but you can´t used saved locations there. I mean, let´s forget the issue of "upload" from edge to connect and see what I want to say.
    Most times you may ride or run on a radius from a location, Doesn´t matter if you home or anyother. If you save diferent locations, you could make different courses in the way the "roun-trip" does.  Lets say you have locations A, B, C .D.,E, you can make on the Explore a course like this,   A then C, then B, then D, and try any other combination (in the way the round-trip works, but "custom".  You can do that on the Explore.
     I don´t know if there are other online apps more then the Garmin Connect to create courses on the same way?  On Garmin connect you must search and locate every time a location for a course, instead of just selecting a combination of locations already saved.
    From my point of view should be very useful, and many people should use it,  if you think making the courses on the edge is too small screen.., should be nice to can to the same thing online.., I mean use saved locations, combine them for a course, save the course.
     I have read threads asking "I have a lot of course on my edge i shoule like to share" and reply is "you can´t" or must use a computer, with that reply how "many people could be using it"?
    Thank you for your replies.
    Any other similar web that allow fenix and Edge?
  • The conclusion about "there must be no many people doing that" because if so should be implemented is a fish that bits it´s tail.
    No, it isn't.
    Garmin can't provide every feature people ask for. There has to be some way of prioritizing what features to add.
    It's not that hard to get reasonable estimates. No one is going to add a feature just to get an actual number. It would be too expensive.
    There aren't that many threads about it (as far as I can tell). Garmin certainly doesn't implement every idea posted here. So being a suggestion is clearly not enough.
    I've never seen any of these threads. Given that there's a limit of 100 courses, clearly Garmin doesn't think people are archiving courses on their devices.
    So, no, there isn't any indication that this would be a widely-useful feature.
    What are these locations? I've never created courses this way.
    It's an interesting idea. I think you can do it on BaseCamp. But I don't think any of the online course creators let you do this.
    Part of the reason is that the Edges can't use "route" files (files that only contain waypoints).
    The Explore website is mostly targeting "hikers" and they tend to use devices in a different way than people use Edges.
  • What are these locations? I've never created courses this way.
    Easy,  if you live in a location, and you have mountains with roads in a radious for riding, you may have different round-trip options. You can just save some locations of diferent elevation points on the road.
     On navigation, you just add one destiny, from A to B.
     On the Edge Explore, you can save different locations on your radius, and one day you may want to go from A to B to C, and other day may want go from A to E to C, different distances, and elevation profile depending on the training you want to do. It´s useful quick to do a course and preview it on the Edge explore this way without have to do it manually every time
      Maybe could do it on Basecamp,  Not sure about alititude profile.
    Anyway, if have to use a computer, I could just send the files from the Explore 2 to the Fenix, just to have the same course on both,  wireless share could be better but if no, I´ll do it manually copy paste the saved course from the Edge to the Fenix (or just use the Fenix to record the activity and the Explore to navigation.
