Learning to use the Edge 840
Hi Folks,
Long time Garmin user and fan here. I started with an Edge 705 for cycling, and eventually upgraded to an 800 and I've been using that same unit up until now.
My work mates gave me a brand new Edge 840 and, well, I'm lost. I just cant figure out how to navigate this thing. The last few rides I've gotten so angry with it I just switch it off and put it away in my pack.
This is no good, why have a GPS if I cant use it!
So, I'm not here to rant and rave, I'm here to ask for help - what tutorials or guides exist on how to navigate the menus on the Edge 840 ?
I have found I can download the tracks via the Garmin Connect app, but its slower and more cumbersome than putting a GPX file on the SD card.
There's a bunch of other questions about maps, but I think I need to start with learning to use it properly first. :)
  • I definitely sympathize.  I started with a 705 back in 2010.  I had a number of different Edge units since but the 840 was a big change in the UI and organization compared to those.  It was a learning curve.  The first thing I did was figure out how to turn off all the automatic features like ClimbPro, Forksight (Mtb), Road hazards, Auto rerouting, etc etc.. That made it more manageable to use while riding. Working through the 840 manual got me partway there, and from there just poking around and figuring things out as I went.  I create courses in RWGPS, and also upload courses from elsewhere there.  From there, they can be wirelessly downloaded to my 840 (usually).
  • Thanks @looigi!
    I did a ride yesterday, I got the RWGPS and this time I authorised it to publish the route directly into Garmin Connect. This actually worked pretty well to get the route onto the device.
    However, I obviously marked it wrong, and when I was riding the course the Garmin kept trying to re-calculate, 3-4 times it just came up with something about "recalculating error" which felt a bit crappy. Fortunately, I knew where I was going anyway. So I'll try switch that stuff off.
    I also found a Youtube video about setting up the data screens, and I think this helped too, I can navigate them easily now.
    One thing I'm not clear on is there's a screen with shows "Mountain" and has my last route and a hamburger icon, and then there's this other screen with the battery ad GPS signal and stuff, and that one has its own left/right pages you can navigate with the up/down button. I just cant get my head around all these different modes - I just wanna ride my bike man! ... and hopefully know where I'm going.
  • 1. RTFM
    2. Disable all features you do not use (yet)
    3. You can still pull gpx-files to the /Garmin/Newfiles directory on the edge
    4. You can email a gpx to your smartphone and when Garmin Connect is running on it you can then save the gpx-attachment to Connect and with Connect sync it with the Edge.
  • I just got an Edge 840 because bluetooth no longer works on my 8 year old Edge 820 which is otherwise functional. So far I'm horrified by the confusing UI.  I'm thinking of returning it and will for now continue using my old 820. I can live with no bluetooth by just loading courses and saving activities via USB with the online Garmin Connect website.
  • 1. This does not help
    2. Yes, I think I've done this
    3. Nope, the 840 does not show up as a drive like the old 800 did, I can only connect via the Garmin Connect app on the phone
    4. Thanks, I did not try email, I started with saving from RWGPS then uploading to the Garmin Connect website, then syncing. However as I noted, I've connected RWGPS and Garmin Connect now, so it seem to be more automated.
  • On 2: you have a Mac? I know, from others that can cause issues.
  • The 840 is going to be a tiny bit different to a computer released 15 years ago. The mistake you might be making is trying to continue your old ways of working when the world has moved on.
    You don't create maps then manually download them to your PC, then manually transfer them to an SD card and then copy to the device anymore. The good news is that if you've managed to master that old and horrendously clunky process, you'll easily adapt to the modern world if you try.  It'll also be a revelation to you!
    You create a route.  If you use Garmin Connect, these will be automatically synced with your device, usually within a few seconds. Then... turn on your device, click on navigate, select the route, click 'ride' and you're off! How hard is that?
    For your question of 'navigating the menus', Alice in Wonderland comes to mind...
    • Alice: "Would you tell me, please, which way I ought to go from here?"
    • The Cheshire Cat: "That depends a good deal on where you want to get to."
    • Alice: "I don't much care where—"
    • The Cheshire Cat: "Then it doesn't matter which way you go."
  • So far I find my "transition" from Edge 820 to 840 to be a pain.  I finally got bluetooth working as before on the 820 with a hard reset.  With that resolved, the 820 released 4 months shy of 10 years ago I would hardly describe as a clunky process: Send to Garmin option in RWGPS "pins" the course to the Garmin Connect app.  From there it either automatically syncs to the device once the latter is turned on or is initiated with one click inside the app. Now I have an option to deal with the learning curve of getting used to the 840 (seems a way different UI than the 820) or parking the 840 for now while still using the 820.
  • 3. Nope, the 840 does not show up as a drive like the old 800 did, I can only connect via the Garmin Connect app on the phone
    New(er) Garmin devices use MTP to connect to your computer. (Old(er) devices connected to computers as basic USB drives.
    In Windows, you can open up the device under This PC.
    If you want to connect to the device using a drive letter, you have to install/use other software.
    sites.google.com/.../mtp-devices
  • There’s definitely a learning curve with the Garmin Edge 840.
    My best advice would be to go through and turn OFF as much clutter as possible to begin with, focus on just one Activity Profile and then only add back the minimum of features needed.
    In particular disabling the extra screens and auto scroll helps a lot.
    Menu - Activity Profiles - Choose profile - Data Screens - tap the three dots in the top right corner of the screen and set Auto Scroll to OFF
    Turn all screens apart from Screen 1 and Map OFF to begin with and then spend some time first of all customising Screen 1 with your chosen fields.
    After doing that go to
    Menu - Activity Profiles - Choose Profile - Alerts and Prompts and turn everything OFF in this section
    For Map appearance this is how I have my Edge 840 setup. There are multiple different menus that need changing for this. It’s overly complex!
    1. Menu - Activity Profiles - Choose Profile - Data Screen - Map
    Show Map - Always
    Show Elevation Profile - OFF
    Layout and Data Fields - 2 Fields
    2. Menu - Activity Profiles - Choose Profile - Navigation
    Orientation - Track Up
    Auto Zoom - On
    Guide Text - Never Display
    Appearance sub menu
    Map Theme - Mountain Biking (this seems clearest for all sports including Road)
    Popularity Map - Off
    Map Detail - Normal
    History line colour - light blue (default)
    Advanced sub menu
    Zoom Levels - all Auto
    Text Size
    Map Points - None
    Saved Locations - Small
    Street Labels - Medium
    Land cover - None
    Shaded Relief - Do Not Show
    Draw Contours - Off
    Routing Menu
    Popularity Routing - ON
    Routing Mode - Road Cycling
    Calculation Method - Minimise Distance
    Lock on Road - ON
    Course Recalculation - Prompt with Auto Re-Route
    Route Recalculation - Prompted
    Navigation Prompts - Map
    3. Go back to the home screen of the Garmin Edge 840 and then tap on the Profile Name at the top of the screen to show the actual Data Screens. Scroll through them until the Map screen is visible.
    Once viewing the Map screen press the UPPER RIGHT button once on the Garmin Edge 840 to bring up the Map Options Menu
    Map Overlays
    Segments - OFF
    Popularity Map - OFF
    Course Points - ON
    High Traffic Roads - OFF
    Road Hazards - ON
    Unpaved Roads - ON
    Climb Pro - OFF
    On the actual Map screen I usually have Map Zoom set to 200ft distance.
