My Edge 840 won't reconnect to wifi automatically
I've noticed recently that my Edge 840 doesn't reconnect to wifi. If I clear all wifi settings, then connect to my network it syncs fine. But after it turns off, once it wakes back up, it won't connect to the wifi network. It seems to be stuck in a "connecting" state but never connects. The only way to get it to connect is to delete the wifi network and then re-add it and it works again. This is of course not how it's supposed to work, and is a giant pita.
Any thoughts or ideas?
  • This isn't usually the case for me, but I recently had a wifi issue. I traveled and added a friend's wifi but the next day it couldn't connect. Then when I came home my usual one didn't connect. In both cases I had to restart the AP and re-add the network and it has since worked fine. The edge can only support 2.4 GHz networks, which your AP may turn off if unused, so try rebooting your router.
  • I have the same issue.  If I connect my iPhone to the 840 via BT, then go to Wi-Fi Networks|<network>|Test Network Connection|Connect, it will connect to my WiFi.  But if I have already connected my phone, then why would I need to connect to wifi?  I want it to automatically connect to my wifi without having to connect my phone!
    Come on, Garmin - work on providing better software quality and stop letting your customers test it.
  • When you test connection via GC, it tells the device to do it. Wifi is mainly used for activity and course syncing (which I find BT does better -- quicker) or downloading maps. It's kind of redundant IMO. You can force a wifi sync from the device without your phone under "connected features"
  • I have the same issue. I can configure the WiFi connection and after a restart the device doesn't reconnect. In the connect app I can start the connection with Test Network Connection. I think this issue exists since an Update in May.
  • Same issue here. WiFi won't reconnect unless I "Forget" the network and connect/enter password again.
    (and it won't auto sync with the phone either unless I open the Connect app and manually sync. very annoying).
    Regression introduced in 27.* updates I guess.
    On older GM versions my rides auto synced and uploaded to Strava as soon as I finished a ride. Not anymore.
  • Exactly the same problem here. WiFi sync works nicely directly after I add a new WiFi network, but then stops working the next time I switch the Edge 840 on again.
  • Same issue here. The recent update didn't help. Any comment from Garmin?
  • I actually know the answer to this! So for some unfathomable reason, Garmin designed the hardware on this using sub-standard wifi parts. If you have a Wifi unit that broadcasts 2.4ghz and 5ghz channels using the same name, Wifi will NOT work reliably with the 840.
    THE ONLY solution is to have a separately named 2.4ghz channel for the device to connect to. In my case I just enabled guest network, set that to 2.4 only and everything works. Other options would include renaming your 2.4ghz wifi network to anything so it's not the same as 5ghz, or just disabling 5ghz which is dumb. Anyway, since I did that, Wifi has been bulletproof.
