Slow Startup
Hello,
My Edge 840 takes 1 minute from pressing the start button until it is fully booted and ready to use. It was much faster at the beginning. I think this has been the case since an update last winter (map or firmware). Does your device take that long to start up? What can I do to fasten it up?
  • me too! I also updated the maps after upgrade to 27.13
  • The more activities and courses stored on the Edge, the longer it takes to start. No need to keep them on the Edge since they are available on Garmin Connect.
  • Thanks, I knew, I had many courses and activities stored. I deleted some of the oldest, and the startup duration increased from 55s to 35s
  • Mine has a slow bootup too, and I have maybe a 6 course and a dozen activities on it after having done a full reset a couple of weeks ago.
  • I'm using a 530 but assume a lot code is reused:
    Reinstall the maps with Garmin Express, if currently possible. Garmin Express struggles in last days, so wait if the option is not available. If seen a much faster startup after re-install of already installed maps. I can only guess, maybe some kind of data fragmentation or cache.
    Despite the devices have enough memory, regularly delete not required Courses and Tracks. Why?
    * It makes the startup a little faster.
    * I was told by the support to keep the device memory somewhat clean, it could cause instability and crashes/reboots. Since I do this it never failed again. Should't be necessary but it works now fine.
  • Hello,
    I use an Edge 840.
    Before updating to 23.17, the boot time was 42 seconds. After the update, it was 63 seconds.
    I uninstalled and reinstalled the maps (using West and Central Europe). I deleted all courses and activities. The boot time is now 42 seconds again.
    When I bought the Edge with OS 9.xx, the boot time was 23 seconds.
    With one of the last ( many mostly pointless) updates, the boot time got worse.
    This is my experience.
  • I found over 200 activities in the activities folder. The edge only showed about 70 in the protocol history. I deleted them all and reseted the edge 840. Now it seems to boot a bit faster again.
  • When I got it the startup time was amazingly fast, like seemed like 15 second. Now it is taking 38.6 seconds...with 0 Actiivities and 0 courses. and after a factor reset and nothing configured..... 33 seconds. Something change in the firwmare to make the start-up time take much longer.
