Garmin Edge 840 does not connect to Garmin Express
I just received the device today. It synced with the Garmin Connect on my iPhone automatically and asked for software upgrade. Then I wanted to connect it with Garmin Express on my mac, but it won't find the device. I use the latest Garmin Express 7.24.0.0 and Software version 24.55 on the Garmin 840. I have other Garmin Devices connected to this machine OK, i.e. - Edge 830, Forerunner 920XT, Varia Bike Radar, and Garmin nuvi. All devices work OK via USB. Any idea what can be wrong with the 840?
  • This fix worked for me running Monterey OS on an old Mac pc.  You connect the 840 OFF and it starts automatically per 2 above, then do 3. Thanks v much as I spent a lot of time trying to find an answer to why it connect sometimes and not on other occasions, with my Garmin Connect app freezing resulting in my having to force quit it.
  • Here is my experience with Edge 840 on a Macbook Pro M4
    Setup:
    After several map-auto-update attempts that failed my Edge internal storage got fully filled up to the point it was showing -377Mb of space. Of course, one is not allowed to remove maps directly from device.
    The firmware on my device was somewhere around 24th major version that is quite old as of July 2025.
    The Garmin Express software couldn't see my device. Garmin Connect on my iPhone, however, could.
    Here is how I got out of this situation:
    - I've requested a firmware update on my Edge, but when it shown me that "transfer is already in progress" I've forced it to use bluetooth. This way it started to actually show progress, and after only 20 minutes it managed to download a firmware update of sorts and proceed to install it.
    - To my surprise, installation of the update require Edge unit to be disconnected from ANY usb cables, even if it provides only charging.
    - Even to bigger surprise, the firmware that was installed this way wasn't the latest one. But, new enough so the Edge connected to Garmin Express (if you removed any MTP software that tries to connect from your computer — Google Drive, Dropbox, Androind File Transfer and so on).
    - I've seen in Garmin Express that indeed, the storage space is beyond spent. Luckily, it allowed me to delete all the maps from Edge.
    - After each operation it requires to reconnect, otherwise it cannot go further, so one manipulation with maps per connection.
    - Garmin Express installed maps I've requested, and also installed a firmware update that was a bit newer.
    - After that when I have booted the Edge without connecting it to USB it downloaded and installed what I believe the really latest version of the firmware to this day, version 27.14
    Finally, I have my Garmin Edge 840 with newest Garmin maps of Western and Central Europe, and with newest firmware also.
    But my journey didn't end there. I like to use a special map for navigation in the Netherlands — it is made from OpenStreetMap data and it gets updated every month. With all the construction work that is happening in the Summer it is rather handy.
    Before (in March, to be precise) I was able to connect my Edge to the Macbook and it would show itself as a thumbdrive, where I can just copy gpsmap.img of desired map and be done with it. Now however thumbdrive method doesn't work (I don't know who is to blame here, Garmin or Apple).
    So, I needed to install Garmin Basecamp, Garmin MapInstall and Garmin MapManager. Last two come in one .pkg file that is quite outdated, it is from 2022, and I am surprised that it still works.
    After installing these, one have to open downloaded map (only in .gmap format, mind you) with MapManager and install it to the special folder that is considered to be Garmin folder of truth on your mac. For me it was inside ~/Library/Applicatio Support/Garmin/Maps/... folder.
    When it's done, one can use Garmin Basecamp to have a look on the map. Careful though, one shouldn't have Basecamp running when map installation to the device is ongoing — failures happen.
    So, last step was just a breeze — run Garmin MapInstall and politely ask it to install the map we've downloaded and installed to a special magical folder to our device (that is of course must be connected to USB and NOT be in MTP mode).
    I wouldn't say that this is the shittiest UX I've seen in my life, but it is a close contender for the first place.
    Edit:
    Map that was loaded by Garmin MapInstall doesn't show on device! Version of the same map from March that was copied in thumbdrive mode works just fine! It's a joke, not a software
    Edit 2:
    I have used a Linux laptop to connect to Edge using MTP mode, and copied a map to it directly. It worked.
  • Thank you! Thank you! Good information....as you stated "who is to blame here, Garmin or Apple."...it does not matter. Garmin should be embarrassed. This is a known issue for over 7 months. Garmin should fix it.
    Im an old guy, I just want to drag and drop files to add courses. I have a library of them on my Mac. Jumping through these hoops is frustrating.
  • My MAC with the latest version of express - cannot find my edge 840.  Garmin just told me that it isn’t their problem.  I’m lost at this point.  Suggestions ?
  • Ok I got this to work. You need to use OpenMTP https://openmtp.ganeshrvel.com .  You can't have Garmin Express connected at the same time so quit that and disconnect/reconnect your Garmin device. In OpenMTP Settings--> Enable auto device detection.  Settings--File Manager-->Turn off "View As Grid" for both Computer and Phone.
    Then
    "Click on the AC plug icon -->Kalam Mode.  The Garmin folder should appear.  If not then, click on the Micro-SD card icon--> Internal Storage.
    HTH
  • Same issue and solution here. I explained that to Garmin support but it's as they don't know this issue.......
    Disturbing...
  • Where is the GARMIN folder suppose to appear ?  I followed what you did and I think that I have it right - but I don't see a folder named GARMIN anywhere.  When I try the Micro-SD card icon - nothing changes.
  • I assume you are running on a  Mac. I would first reboot as that should ensure no other programs are using MTP mode. I then run OpenMTP. On the Right Hand panel you should see in Red "FAQs- My Phone is not Connecting!
    Check the settings (Gear symbol) and ensure tha auto device detection is on and that MTP Mode is Kalam. Plug in your Garmin 540 series.   When you click on the AC Plug icon on the right hand side, the Garmin should have a USB-connector and cable near the top.  On the Botton right there should be a triangle , which indicates that you can disconnect.
    At this point I now see a Garmin folder on the right hand side of OpenMTP screen.   As before if I didn't see this I would press the SD Card symbol.
    If you don't see the USB Connector and cable on your Garmin it won't work. At that point I would check the firmware version.
  • This is so frustrating!  I have a Garmin Nuvi, Approach 6 & 8, and Edge 1040 and all those devices connect to Garmin Express and update without issue.  I try to use the same computer and cables and the Edge 840 will not connect.  Have tried to force the 840 into MTP mode and that used to work but now that no longer works.  I actually tried to contact Garmin support and they were of no help whatsoever. :(
