How do I turn off all beeps on the edge 840? Is this not possible? I already have tones and key tones turned to off.
BEEEEEEEEEEEP
BEEEEEEEEEEEP
I as well hate hearing any beeps and have them all turned off.
I have a 530, but I'd assume the 840 can be soft reset like the older models by holding down the power button until it shuts down. Often solves a multitude of problems. Check your tone settings again after the soft reset and make sure they're still set to off. A soft reset shouldn't change any data or settings.
The Garmin Edge 840 continues to beep at me when I do not want it to. If you google search "Garmin Edge 840 beeping" you will see there are a lot of people who do not like this beeping! It's very annoying and can be disturbing to others nearby. I might be returning the Garmin Edge 840, Varia UT 800, and VariaTM RCT715 because the Edge 840 beeps at me when I do not want it to.
