Edge 840 red border with red arrival flag
Suddenly a red border can show up on my bike screens, accompanied by a red flag... Out of nowhere.  While this happens, navigation continues, but distance, time and all other values are no longer captured.  Reviewing the activity, a line is drawn from the popup timing to arrival that says 'hidden'.
What is this red border ?
How to avoid or deactivate?
Many thanks !
  • It seems that you going into auto pause mode. Is the border really red? Look at the timer settings in your profile.
    0 Former Member over 1 year ago in reply to lhol
    Thanks for your reply !
    Auto-pause turns the whole screen grey with a pause sign laid over.
    Here, there is a red border along the whole screen with a red arrival flag on the right hand side. Remainder of the screen is normal.
    I cannot find any explanation in the user manual...
  • The only way that I can make the "red border" screen appear (on my 1040) is by pressing the bottom-right START / STOP button while an activity is active (ie STARTED). It is possible to enable an auto-start but I don't know of any setting that does an auto-stop ? The 840 also has other buttons so maybe it is possible to arrive at the red-boarder screen via some combination of other buttons?
  • The only way would be an accidently push of the timer button unless you have configured the button control options of a Di2 or compatible SRAM system to be start/stop. (or Edge Remote)
    0 Former Member over 1 year ago in reply to L.Rouge
    Many thanks.
    I recall that during my ride, the unit powered of all by itself... What shouldn't happen even not when I hit a bump fairly hard.  Took a while to reboot.
    I may have hit the Start/Stop to get it going again... While it was already going.
    I hit this button a lot when performing HIIT and am crossing streets : no such red border screens.  I presume this coached workout is not seen as an 'activity'.
    Is all this in the manual somewhere?
    Thanks again.
  • If the unit crashed and restarted then yes it would have stopped the activity upon the restart and given the red boarder.
    0 Former Member over 1 year ago in reply to aweatherall
    All sorted now.  I just need to press START again to get going.
    Does your unit crash at all ?
    Tx.
  • Does your unit crash at all ?
    Mine (1040 version 24.19) does not and never has crashed, frozen, re-booted, (bit over 2 years old), I install every beta so should be a sitting duck but I also use a minimum of the device features and certainly almost nothing that was new in 23.xx & 24.xx (some of which seems pretty buggy), minimising features (& almost no backlight except night) equals minimising processor load / memory usage and means I also get 90 hours plus from a charge, I do longer rides and reliability / predictability is more important to me, I am happy, just hope  I can kept it going for 10 years or so, if I can get a slightly larger location symbol on the map I will declare it perfect (for my type of riding).
    Good to read.
    You are managing your unit to a great extent. Impressive how you have prioritised matters.
    I agree that the navigation map could be better.
    I will update my unit today Smile
