Custom POI not custom zoomable - need their own category for zoom level
On the 800 that i've upgraded from you could set the zoom level for POI that you have uploaded, but on the 840 however much I change the zoom levels (and I believe 'map points' is the correct one).  The zoom level at which my custom POI are visible is 300ft, no greater. I get that the map can get cluttered if I want the visible at 0.5mi (which I do), but I can live with that.  However it seems a no brainer to have  a separate category for custom poi, and then you can have all the, to be frank, pretty useless to me 'out the box' poi/map points only visible at a high zoom, and control your own poi independently.
  • Im agree, adding to this topic.
    Custom POI, that I will be able to adjust (tick on/off what I want to see) as I dont need to see Car parks, or car sharing POIs ect.
    Agree as well that we need to see POIs from greater distance (zoom out level), as when I search for a POI I have to look from greater distance, for me personaly most important are water points which finaly we can see them so I am VERY GREATFULL for that.
    Thank you Garmin
