Hi. I have observed something not correct while charging. The scenario in which I am able to repeat this error many times is: the device is in sleep mode, then I connect the USB C charging port (not waking up the device), the Garmin logo and charging icon appear on the screen. After some time (different in each case, random), the device shuts down on its own (the logo and charging icon disappear) and charging is stopped. I then press the Wake up / Power on button and the device is indeed turned off, as the operating system restarts.
Have you observed something similar?
When I connect and start to charge the device in the active state, the charging proceeds correctly to the end (to 100%), or when I connect the charge and then switch off the device the charging also proceeds correctly.
