I've played around in the settings and I can't find a way to disable the "virtual partner" on my Garmin 830.
Am I just missing something? Seems like it should be an easy thing to disable.
The “trick” works perfectly on x40 devices but unfortunately not fully on x30 as they don’t fully support all the MapTheme elements. Doesn’t work at all on 1050 as the MapTheme functions have been removed…
For some reason, Garmin considers virtual partner that essential that it cannot be disabled; this despite the fact that so many users ask for this very simple implementation. Another contempt to Garmin…
Disabling VP has been requested many times by many people. Garmin has not even acknowledged that this is something the people want.
You are correct it cannot be disabled. There are a number of long threads on this topic.
For some reason, Garmin considers virtual partner that essential that it cannot be disabled; this despite the fact that so many users ask for this very simple implementation. Another contempt to Garmin's customers, their revenue source.
I saw something in this article recently where someone claimed to have disabled it using custom themes. I haven’t tested it and given the lengthy threads it probably won’t work, but needless ctccambridge.org.uk/.../garmin-tip-making-route-easier-to-see
The “trick” works perfectly on x40 devices but unfortunately not fully on x30 as they don’t fully support all the MapTheme elements. Doesn’t work at all on 1050 as the MapTheme functions have been removed from them.
The “traditional” trick with the VP is to set the course speed (which is used by the VP) very high so it races ahead or very low so it lags well behind. All still use processing cycles.
