error installing map update
Hi,
my Edge 830 in on version 9.73
Multiple times I tried to install the "Routable Cycle Map of AU and NZ 2022.0"
Every time I get the error: "There was an error installing the update"
What I have done so far:
1. Check storage available on device. It has 10GB available; means storage is not the issue
1. remove device from Garmin Express and re-connect subsequently
2. re-install Garmin Express
3. delete all *.img, *.gma, *.unl except gmaptz.img from the Garmin directory of the device
 Despite the effort, I still get the error message.
What can I do to install the map update? Is there a workaround or a fix?
thanks
Norbert
