Map Update fails or won't unlock
The initial update succeeded but the device displayed a message that it couldn't unlock the map. The update still shows on Express as available but now I cannot install it.
Things I tried:
-Going into Details and Reinstall. The process completes but the result is the same.
-Reinstalling Express.
-Running Express as Admin.
Any ideas?
  • Is this the map that came installed on the 830, or is this a supplemental map you purchased separately?
  • The map came with the Unit. I bought the unit from the local Garmin distributor in Argentina.
  • Started getting errors after the first update attempt.
    I just tried factory resetting the unit. Right after reboot got the map unlock error again.
    Tried with another computer, fresh Garmin Express installation, the map update fails right away.
  • One more thing I just realized. Express shows an update available with version 2019.10. The unit has already 2020.20 installed.
    Powering off and on the device I still get the "cannot unlock map" error.
  • I have the same issue. I think this is happening  because the available empty space in my case is 5.5 GB and the update needs 9.6 GB
  • I think I figured out a work-around.  At least the maps are being downloaded to my 830!
    Go into IQ on the Edge.  Select Trailforks.  When asked if you want to log into Trailforks, select the X (not the checkmark).  You will then get a Trailfoks page with My Routes.  These are ones that you have saved in your Wishlist on Trailforks.  The first time you open a map, it will doiwnload to your Edge, and then be saved under Saved Courses.
    Seems kind of kludgy, but it works, and I didn't have to uninstall/reinstall anything.
  • I think you got it for the annoying "cannot unlock map" message. I've never used Trailforks and didn't even have an account. I created one and logged in with the phone and right after I clicked the Trailforks option on the unit I saw an "unlocking map" message. When I plugged it to the computer it downloaded an update but I don't think that was even necessary.
    When I turned the device on again, the cannot unlock map message went away.
    The original problem I reported, the map update not installing went away long before.
