I just wonder if is possible to replace a battery in Edge 830 or 530 on this same way as in 520 I haven't seen any tutorial, anybody know ?
Yes it is possible but as Martin points out, the process is probably similar to the 820, for which there are videos available. The 830 is not designed to have the battery replaced so it's not easy or straightforward. If your batter is bad, consider a warranty claim. If it is out of warranty coverage, you can exchange it for a refurbished unit, which will have a new battery and be indistinguishable from new for something like $150
Hi, see Martin point. I know the 830/530 are not designed to replace the battery as all edges. The question is if the method is the same as 820? If yes, that would be good the reason why I'm asking is because I want to buy 830 but as you know probably after 2 years even earlier battery
will hold energy much shorter that's why wanted to know about the possibilities of replacing. But probably until somebody do this first time we can't be 100 percent sure. Thanks
Probably not necessary to change out the battery. Just get the Garmin Charge Power Pack and use the external battery connection built into the mount.
