Two days ago I updated the firmware of my Edge 830 from 3.20 to 3.50.
Since then I had problems with the speed during a 1.5 hour ride. The speed was continuously inaccurate (varying between the actual speed, half the speed and 0) while GPS was working fine (I was correctly positioned on the map).
After the update to 3.50 I tried the following:
- Reboot the device
- Different GPS settings (GPS, GPS+GLONASS, GPS+Galileo)
- Device reset
- Device reset to factory settings
None of these measures worked. That's why I reinstalled version 3.20 of the firmware. After that, the speed was accurate again.
Then I reinstalled version 3.50 and the recorded speed and distance were off again.
I will attach two screenshots and FIT files of two similar test rides of about 20 km/h I did with the two different firmware versions (3.20 and 3.50), both after a complete reset of the device.
I hope the issue can be identified and fixed.
Kind regards,
Sander
