830 will not turn on
I had a strange problem today.  I charged the unit using a charger (not the computer) and the 830 powered off as expected when full charge was reached.  However, when I went to do a ride, I could not turn it on.  Tried the power button many times, also held it >10 seconds to try for a reset.  Nothing worked.  I then used the USB cable to plug it into the computer.  that powered it up and after that, could power up and down with the power button.  I looked for an error log file after my ride, but could not find one.  Any ideas?  I will have to do some testing to see if this repeats.  Note I am running the beta firmware.
  • Indeed very strange.  Hopefully Garmin will take a look and make sure the bug doesn't get into a released firmware.
    +1 Former Member over 5 years ago
    I've had the same problem three times.
    After pressing the power button for a long time the Edge started.
    I am using the software 3.20
  • Did it happen after charging? or just randomly?  I have not had it happen again, although I have not fully charged it again either.
  • It happen after full charging
    0 Former Member over 5 years ago
    HI, I am having the same issue, device initially comes on then shuts down in less than a minuet (its charged) this also started after a full charge
  • Hmmm I'm having the same issue on latest beta firmware.  I tend to leave it on the charger for a few hours, and it has trouble turning on requiring a really long press (10+ sec).  Has happened several times now.
  • Could you post the err_log.txt from the Garmin\Debugging folder if there is one?
  • this is from today:
    "unit_id":"3301178944",
    "product_name":"Edge 830",
    "software_part_number":"006-B3122-00",
    "ms_since_epoch":1563973969000,
    "system_version":"3.55",
    "build_type":"PRODUCTION",
    "backtrace":" - Error type ( 8 ) err( 8 )",
    "error_cause":"8",
    "proprietary_info":{
    "Commit ID":"f36bd8ca6f965fc2ef16328767cfe5737c5c9e94",
    "Time":"2019-7-24 9:12:49",
    "Ram Dump":"N/A",
    "ESht PC":"0x00000000",
    "ESht SP":"0x00000000",
    "Project Specific":"
    M4 SSRS: 0x6
    M4 SRS: 0x6
    A7 SSRS: 0x6
    A7 SRS: 0x6",
    "Task ID":"0",
    "Task Name":"",
    "R[0]":"00000000",
    "R[1]":"00000000",
    "R[2]":"00000000",
    "R[3]":"00000000",
    "R[4]":"00000000",
    "R[5]":"00000000",
    "R[6]":"00000000",
    "R[7]":"00000000",
    "R[8]":"00000000",
    "R[9]":"00000000",
    "R[10]":"00000000",
    "R[11]":"00000000",
    "R[12]":"00000000",
    "R[13]":"00000000",
    "R[14]":"00000000",
    "R[15]":"00000000",
    "cpsr":"00000000"
  • from a few days ago, unsure if same problem:
    "ms_since_epoch":1563719136000,
    "error_cause":"8",
    "Time":"2019-7-21 10:25:36",
    "Ram Dump":"N/A",
    M4 SSRS: 0x6
    M4 SRS: 0x6
    A7 SSRS: 0x6
    A7 SRS: 0x6",
    "Task ID":"0",
    "Task Name":"",
    "R[0]":"00000000",
    "R[1]":"00000000",
    "R[2]":"00000000",
    "R[3]":"00000000",
    "R[4]":"00000000",
    "R[5]":"00000000",
    "R[6]":"00000000",
    "R[7]":"00000000",
    "R[8]":"00000000",
    "R[9]":"00000000",
    "R[10]":"00000000",
    "R[11]":"00000000",
    "R[12]":"00000000",
    "R[13]":"00000000",
    "R[14]":"00000000",
    "R[15]":"00000000",
    "cpsr":"00000000"
  • I also cannot switch the device on via Power Button. Confused
