Latest 26.18 gives completely wrong climb rates. I run same roads many years and a few Garmins before. After the update the Edge 540 went a mess! Anyone else notice that?
I can confirm that also on my Edge 540!
Cheap 20 Euro bike computer could it better!
"Quick fix"... yeah, whatever.
These days I had an issue with the altitude being approximately 150 m off during the whole ride.
It seems as if the device still has issues with its barometer, and…
Same issue... Goes negative when I go uphill and change degrees every 5 seconds
The same issue for me.
And - maybe related to it: when I'm on uphill with ClimbPro screen, being close to the hill top, maybe 50-75m, but still in the inclined part. Then, the climbpro gradient shows 0% and beeps that I'm done with the hill, while still having some distance to the peak.
I've found there's always been quite a disconnect from actual gradient, and previous garmin
eg where climb finishes
or gradient changes, but that was just out of sync
This issue i think is the instantaneous percentage gradient, Doesn't remotely match what the Garmin climb screen would indicate, on a section of climb what was 6-9%, the displayed figure was between 1-4%
Changelog mentions: "Improved altimeter accuracy with barometer outlier rejection"; does not look like grade percentage improvement to me.
