Two rides without info about turns, graphic or audio. GPX made in komoot, dropped to connect. Got second edge 530 and there it works. Look at the distance left.... 5879km, should be ~30km Whats the problem?
Hello, everything default.
Intl standard basemap - on
topoactive europe east 2025 - on
garmin dem map eu 2023 - on
topoactive europe central 2025 - on
topoactive europe west 2025 - on
garmin soft 9.75
it was working and few days ago when i loaded gpx and then it ended like this, no change was done before this happened, unit is stock without any third party stuff
I did removed every saved activity from device with all fit files, saved only those two on pc that i shared... i think the theory is possible, maybe selecting other gps service on the device might change something? like from glonass to galileo?
Another thing to add, yesterday i was testing the device and upon loading one of 3 courses i opened the map and to my suprise it loaded 2 of them in the same time. WHAT the heck... i deleted one of them that was this i didnt wanted and loaded again and it worked. Im starting to think about wiping the device clear. Or is there a way to extract logs from it to see what happened?
You can download the activity FIT file from the browser-typed Garmin Connect (not from the app), go into the activity, top right there is a cogwheel icon, and "export file", that is the original FIT file from the device itself.
the Galileo is much better, more accurate, do not use Glonass if possible (i used my 830 with +Galileo only). (i see that you are living next to Katowice, that is not close to the war zone but a GNSS spoofing is very common now unfortunately, probably there is a military base or spot where you rode , i didnt check the route very deeply)
i think a full device reset would be helpful , probably more files/settings are corrupted there (dont you get error message when you plug in your Edge into the Windows PC?)
fit - limewire download - here is the file i downloaded from web connect, as far as i can see there is nothing wrong with the grid but maybe you will see something
ill try with galileo today and you are right about military near where i live... like 10meters from my house is unit and the gpx went through another base and civilian airport but it wasnt a problem on 300+ rides
sadly i dont get any errors, device connects perfectly to the windows pc
did You get that +5k km distance to go before or after the stop at 43km (i see an autopause/pause stop at Niwiska)? i see the airport is next to it, so anything could happen with spoofing.... yes, in the past it was not so common problem but since the war, it is more common problem and these consumer GNSS products cant handle that (even the pro devices suffer but there are many developments to eliminate this)
do the full reset on the device and +Galileo and lets see what will happen
