Edge 530 doesn't keep his configuration; it asks new pairing with APP Connect after rebooting
Hi,
since one year, my Garming 530 (9.75 firmware) suffers of this problem: after powering on, it starts asking a new configuration steps.
Since it is already paired with APP Garmin Connect, in order to make it works, I need to remove it from the APP (so I lose the current configuration) and then I've to pair it again to APP.
I've done many reset but the issue has been not fixed. Now I've asked for RMA but I would like to know if someone has faced same issue on his Garmin device.
Thanks for the support.
Alberto
  • Mine is fine with 9.75 and iPhone.
    Perhaps try setting it up like a new device ie:
    Delete the Edge Bluetooth connection on the phone.
    Delete the phone Bluetooth connection on the Edge.
    In the GC App, remove the Edge as a device if it’s there.
    Reboot the phone and Edge.
    Start the pairing process again as per the Garmin Instructions.
    Pairing Your Smartphone
    Optionally, delete and re-install the GC app on the phone.
    The above steps are for the worst case, not all may be needed.
  • Thanks Peter for your feedback.
    The steps you reported are all those ones that I've to do once the issue happens.
    So I'm just re-initializing again the device.
    Then, maybe one day later, after powering on it, it starts asking the language and I've to re-initializing again.
    It doesn't keep the configuration Disappointed
