I recently updated my "530" with the new map, EU 2024.10, which went well with no issues, just over 20 minutes instead of the forecast 3 hours.
But now I am left with a start up problem, its taking up to 2 minutes for the 530 to start, which is not a problem if I am not in a rush to get going, but it is a big problem if I need to be away quick and others are waiting
On turning it on, the startup "Garmin" screen appears, then the screen blacks out, followed a short while later by it reappearing
Start up then commences as normal and informs you its loading maps etc
Then it comes to the next screen informing you to that everything is loaded and "Press any button to continue", but the 530 just hangs on that page for nearly a minute which is far longer than it has been in the past, it would only be a few seconds.
If you attempt to press any button to progress, nothing happens. But when it finally does start, if you have pressed a multitude of buttons to try and make it work, you find that you can have changed menu's and settings etc because despite the screen being locked up, the buttons and functions are still working in the background.
Sometimes when it starts, it also justs hangs showing a small screen in the centre of the display.
If I disable the EU West map that I am using, the 530 starts up as normal even when I have an OSM map enabled.
Over 3GB of free space is still available on the 530
