Garmin Edge 530 in boot loop after update
Dear Forum,
last Sunday a connected my Edge 530 to my Mac running  Os X Catalina to check if some updates were available through Garmin Express (version 7.15.00). Four updates were found and I started the update process.
After a few seconds, the Edge rebooted and loaded the Garmin screen showing version and model. Then rebooted again and a again in a loop.The boot process arrives to the same screen described before and reboot making the classical startup beep.
I tried several solution found in the forum but none worked. The only thing I succeeded was to punt the Edge in storage holding the Lap button mode while connected to the Mac.In this way I also removed the GDupdate file inside, to allow the new update installation.
I found in the forum several button combination but none f the worked and also in the manual I didn't fount anything.
I didn't understand wich is the button's combination that allow to perform the factory reset.
Thanks to everyone that will help me to solve this issue.
Thanks again.
Luca
