Garmin 530 - sensors not loading automatically
Garmin 530 - I have to manually reload all my sensors at the start of every new ride - they used to load up automatically….. help
  • What is your software (firmware) version and when did the issue start (recently? , after a software update?) Have you looked at the many sensor dropping / not connecting forum topics (in 530, 830, 1030, 1030+ forums, the software is the same.
  • It’s the latest update on software and started happening recently
    do you have a link to the forum with similar probs
  • Try searching for sensor drops in the search bar of this forum.
  • There are dozens scattered in the 530/830/1030/1030+ & now 1040 forums, many recent but also going back years. They are of two major varieties, sensor drops & sensors not connecting/re-connecting. They seem to come in waves, often clustered after specific software version updates, 9.40 the most recent with lots of reports but 8.00 also a lot. Garmin does not recognise this as an actual problem, many users do not have the problem but many do have it and they will often revert back to a version they believe minimises or eliminates the issue, 9.10 & 7.10 are popular versions to revert to.
    As Peter says, just search in the sub-forums or just scroll back a page or two of topics, other than reverting or perhaps not using bluetooth connections there does not appear to be a common or consistent solution.
    Eg this on the second page of 530 topics forums.garmin.com/.../edge-530-dropouts-since-9-30-update
