I use my Garmin 530 for my daily commute to work. When I arrive at work I always pause the ride and turn the device off (sleep mode). For my way back home I turn the device on and hit the start button again. This always works fine until yesterday. The ride in the morning was recorded but the way back home was not recorded as a route on the map. Strangely the distance is correct. It's 19 km one way, and in Garmin Connect it shows 38 km total, but only the morning ride is showed on the map. I checked the map on the device itself and shows the same (half) route.
I ride with a combined speed/cadence sensor connected to the Garmin (ANT+). The GPS is turned on in the chosen activity profile (just checked). For the ride back home the battery had about 20% left in it. When I arrived home it was at 17%.
I appreciate any suggestions...
