For those who upgraded from 130 model, it's just me or the screen is worse than the smaller unit? For me it's even harder to read with cycling glasses.
The display in the 530 is designed to readable in direct sunlight. If you are having issues reading the display in more shaded environments, we would suggest trying to alter your backlight settings.
Please…
I have always used my Garmin units, 510 and now 530, with backlight always on and now with 530 I enable auto brightness. With 510 I think I had it on one of the lower brightness settings. I don't notice…
Profile color has no effect on background color. I tried also the screen rotation but I have not noticed any difference, with or without glasses. Mine are not polarised. A slight improvement, as I read…
530 is good if sun shining direct on screen. If sun is at your back, I can't see numbers . Is to dark...gray blue screen. I went from 130 to 530 because of bigger numbers and screen. But now I have bigger numbers which I can't see..
Frustrating.
Please feel free to take a picture of the setting you are struggling with and add it to your reply, although I understand that it may be difficult to accurately capture this with a photo.
It is recomanded to ride with backlight always on?
I wasn't meaning to recommend that. I was just meaning to acknowledge that some situations will require a backlight to make the display easier to read than others.
I personally have my brightness set to Auto and have a short backlight timeout, but there are a variety of combinations folks can try.
